Changes the configuration that has been configured with the configure mpls rsvp-te lsp lsp_name add path [path_name | any] {profileprofile_name} {primary {frr_profile_name} | secondary} command.
| lsp_name | Specifies the name of the LSP you are changing. |
| path_name | Specifies the name of the path to be used by the specified LSP. |
| any | Configures the specified LSP to use any path. |
| standard_profile_ name | Specifies a profile to be applied to the specified LSP. If the profile name is omitted, the profile named default is used. |
| frr_profile_name | Specifies a fast reroute (FRR) profile to be applied to the detour LSP that backs up the specified LSP. |
N/A.
None.
This command changes the LSP named aus to use any available path:
configure mpls rsvp-te lsp aus change any
This command was first available in ExtremeXOS 11.6.
The fast reroute capability was added in ExtremeXOS 12.1.
This command is available only on the platforms that support MPLS as described iin the Switch Engine v33.1.1 Licensing Guide document.
